Hi!
I wonder if it will be possible to use eGUI with the Solomon Systech SSD1325 OLED controller:
http://www.newhavendisplay.com/app_notes/SSD1325.pdf
If yes, will it be hard to adapt for example the existing SSD1289 driver to this controller?
Thank you for any hints!
Anguel
Hi Anguel, th eGUI software has been exclusively designed to work with Freescale silicon, I'm afraid you CANNOT use it with any other semiconductor brand products or you might face legal issues due to infringement. I apologize for this but our software enablements are aimed to help our customers make a better use of our products.
I AM using Freescale, this is a display controller I want to interface...
Thanks for the hint but I already know about these files.
I am not sure if it is possible to drive grayscale displays with eGUI? The manual does not mention anything about that.
Yes, the K70 LCDC module can drive grayscale displays as depicted in page 2183 of the device's reference manual.
And how is this related to eGUI???
