Hello!
I try compile pango from LTIB, unfortunally this not work:
/bin/bash ../../libtool --tag=CC --mode=link gcc -g -O2 -Wall -o harfbuzz-dump harfbuzz-dump.o harfbuzz-dump-main.o -L/opt/IMX53/ltib/rootfs/usr/lib -lfreetype -L/opt/IMX53/ltib/rootfs/usr/lib -lfontconfig libharfbuzz-1.la
gcc -g -O2 -Wall -o harfbuzz-dump harfbuzz-dump.o harfbuzz-dump-main.o -L/opt/IMX53/ltib/rootfs/usr/lib ./.libs/libharfbuzz-1.a -L/opt/IMX53/ltib/rpm/BUILD/zlib-1.2.3 /opt/IMX53/ltib/rootfs/usr/lib/libfontconfig.so -L/home/kirill/Projects/MobileCam/src/freetype-2.4.11/objs/.libs -L/opt/IMX53/ltib/rpm/BUILD/libxml2-2.6.28/.libs /opt/IMX53/ltib/rootfs/usr/lib/libfreetype.so /usr/lib/libxml2.so -ldl -lz -lm -Wl,--rpath -Wl,/opt/IMX53/ltib/rootfs/usr/lib -Wl,--rpath -Wl,/opt/IMX53/ltib/rootfs/usr/lib
/usr/lib/libxml2.so: file not recognized: File format not recognized
collect2: ld returned 1 exit status
make[4]: *** [harfbuzz-dump] Error 1
Why pango try use system libxml2.so?
Thank you and excuse me my bad englsih.
This problem solved - I incorrect build fontconfig.
Now I solve another problem - fontconfig, I use 2.10, not install libfonfig.la.
Perhaps it makes sense to re-install libxml2-dev on the host PC.
$ sudo apt-get install libxml2-dev
Hello, Igor!
Unfortunally this is not solve problem:
$ aptitude show libxml2-dev
Package: libxml2-dev
State: installed
Automatically installed: no
Version: 2.7.8.dfsg-2+squeeze6
Also why I have to install libxml2 on host if configure found libxml2 on board?
