Hi, pgo
I need your help.
I want JM60 OSBDM - Qorivva MPC55xx/56xx of P&E to transplanting your USBDM 's hardware using the PCB " USBDM_CF_JMxxCLD_V3 ".
The problem is I don't know when to shut down target VDD, when exiting debug mode.
The BDM receives what when exit debug mode?
Can you help me?
I'm unsure what you are doing and what information you are asking. I hope the following is useful.
The target supply control can best be followed by looking at the usbdm API and the usbdm_dll source code.
bye
