Hi i am facing problem to generate pwm (12MH) . The general calls like pwm_request not implemented in iMX28 ...Is there any calls to generate pwm or i have write to register .
Anand
Solved! Go to Solution.
No example of the PWM. Please read this for referenec.
https://community.freescale.com/message/273292#273292
Hope this can help you.
You can see LED driver in iMX28 EVK kernel. This is done via PWM.
