we want to record a mp4 file while preview(overlay) is running.
We have a application which activates the overlay an records a mp4 file on user input.
The error can also be reproduced using gst-launch. (gst-fsl-plugin-2.0.3)
With the gstreamer pipe
gst-launch mfw_v4lsrc capture-width=640 capture-height=480 num-buffers=150 ! mfw_ipucsc ! 'video/x-raw-yuv,width=640,height=480,framerate=30/1,format=(fourcc)I420' ! queue ! mfw_vpuencoder codec_type=std_mpeg4 qp=5 ! 'video/mpeg,mpegversion=4,framerate=30/1,width=640,height=480' ! mp4mux ! filesink location=test.mp4
I get this output and it works.
MFW_GST_V4LSRC_PLUGIN 2.0.3 build on Jun 7 2012 14:48:18.
IPU_CSC_CORE_LIBRARY_VERSION_INFOR_01.00.
MFW_GST_IPU_CSC_PLUGIN 2.0.3 build on Jun 7 2012 14:47:53.
Setting pipeline to PAUSED ...
[INFO] Product Info: i.MX53
VPU Version: firmware 1.4.48; libvpu: 5.3.2
MFW_GST_VPU_ENCODER_PLUGIN 2.0.3 build on Jun 7 2012 14:47:56.
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
mfw_gst_ipu_csc_get_unit_size:size=614400
mfw_gst_ipu_csc_get_unit_size:size=460800
Got EOS from element ""pipeline0"".
Execution ended after 20664847635 ns.
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
With preview=true
gst-launch mfw_v4lsrc capture-width=640 capture-height=480 num-buffers=150 preview=true ! mfw_ipucsc ! 'video/x-raw-yuv,width=640,height=480,framerate=30/1,format=(fourcc)I420' ! queue ! mfw_vpuencoder codec_type=std_mpeg4 qp=5 ! 'video/mpeg,mpegversion=4,framerate=30/1,width=640,height=480' ! mp4mux ! filesink location=test.mp4
I get
[ 444.360024] mxc_ipu mxc_ipu: IPU Error - IPU_INT_STAT_5 = 0x00200000
[ 459.363352] ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0
ERROR: from element /GstPipeline:pipeline0/MFWGstV4LSrc:mfwgstv4lsrc0: Internal data flow error.
Additional debug info:
gstbasesrc.c(2507): gst_base_src_loop (): /GstPipeline:pipeline0/MFWGstV4LSrc:mfwgstv4lsrc0:
streaming task paused, reason error (-5)
Execution ended after 10001064875 ns.
Solved! Go to Solution.
Seems you just added a "preview=true" is not enough.
Please see this link for your reference.
< https://community.freescale.com/message/292568#292568 >
