Problems compiling i.MX53 Sabre compact 7 bsp
c393
I have downloaded and installed the Sabre BSP when I compile the iMX53_SMD_mobility bsp I get the following error:
BUILD: [03:0000001103:ERRORE] Error(s) in directory "C:\WINCE700\platform\iMX53_SMD\SRC\DRIVERS\IPUV3\DISPLAY\". {log="C:\WINCE700\platform\iMX53_SMD\bldsys.log(487)"}
Any suggestions on what causes this error and how to correct it?
Thank-you
Dennis Essenmacher
Tags (2)
c393
Problem solved needed to check catalog items I2c and PMIC and rebuild libraries.
