imx-lib 11.09.01 build error on 2011.09 BSP (L2.6.35_11.09.01)
AhmetYUCE
Google search gives a similar discussion on this forum, but somehow i couldn't find in imxcommunity.org web site. Anyway i have a fresh iMX53 Linux BSP (L2.6.35_11.09.01) install on Ubuntu 11.04 with latest FSL Linux_20201112_20patch_bundle applied. Build of minimum profile interrupted by imx-lib errors, error messages given below. If i remove imx-lib option, build finishes successfully. Anyone having the same problem or solution ? ******************************************************************************* -I/opt/ltib/rpm/BUILD/imx-lib-11.09.01/../linux/drivers/mxc/security/sahara2/include -I../ipu -Wall -O2 -fPIC -c ScreenLayer.c -o ScreenLayer.o In file included from ScreenLayer.c:35: ../ipu/mxc_ipu_hl_lib.h:154: error: expected specifier-qualifier-list before 'ipu_mem_info' ScreenLayer.c:73: error: expected specifier-qualifier-list before 'ipu_mem_info' ScreenLayer.c: In function 'tvmode_system': ScreenLayer.c:115: warning: ignoring return value of 'fwrite', declared with attribute warn_unused_result ScreenLayer.c: In function 'copy_to_tv_init': ScreenLayer.c:148: error: 'ScreenLayerPriv' has no member named 'fbdev' ScreenLayer.c:149: error: 'ScreenLayerPriv' has no member named 'fbdev' ScreenLayer.c: In function '_MemAllocSL': ScreenLayer.c:317: error: 'ScreenLayerPriv' has no member named 'preLayerId' ScreenLayer.c:320: error: 'ScreenLayerPriv' has no member named 'preLayerId' ScreenLayer.c:325: error: 'ScreenLayerPriv' has no member named 'screenRect' ScreenLayer.c:325: error: 'ScreenLayerPriv' has no member named 'screenRect' . . .
