The ^ sign is placed after the equal sign in the expression and seems to point to an issue with the assignment. Furthermore, I can examine the variable fine from the command script, so I think it recognizes the variables, but I can not assign any values to type double.
I tried doubles that are global and local and the results are the same, so it does not appear to be a scope issue. I have structures that contain mixed types and I can set any member as long as it is not a double.
How do I do this? We are just getting ready for verification of our program and are up against a schedule crunch.
Thanks in advance,
Solved! Go to Solution.
