Good day!
Ocassionally have found out this thread about problem with 13192 board.
Unfortunately, frescale's support couldn't help me, so I hope maybe community can advise some solution.
So, I have 2 13192-sard boards (without any staff from kit). And they were used with programm in LabView to measure acceleration.
Somehow, one of board was connected to BeeKit software via Rs232 cable and some data exchanged with it using terminal window in BeeKit SW.
So, after that it works wrong - after power on the 4 LEDs light (instead one as before) and no data exchanges using radio.
Can you advise something, because I have no USB Multilink cable, so I can't upload new firmware from CodeWarrior.
Moreover, I guess there should be some solution using rs232, because if it could be damaged using it why it couldn't be repaired the same way?
Thanks a lot! Sorry for my bad English)
I think if you really want to use the board, you need get access to a BDM programming cable (e.g. P&E Multilink). I do not believe your board has serial bootloader on it. Without it, you need to debug/program it through the BDM connector.
Hope this helps,
BK
