MC9RS08KA2 A/D conversion
jackabo
I had a message posted before about using the AN3266 document to do A/D conversion for my MC9RS08KA2 and I have almost debugged all of the code. However, there is one section of the code where the Page Selection Register is initialized with the code of "mov #HREG, PAGESEL" However, there is no variable called HREG in the document. Does anyone know if this vaule is just $00 or is there some other value that is used to set the PAGESEL to an initial value? If anyone has any ideas please let me know. Thank you.
Jackabo
bigmac
Specialist III
Hello Jackabo,
I would guess that HREG is the value that should be in PAGESEL, so that the high page registers ($0200-$023F) are visible in the paging window.  If my reckoning is correct, the following definition would apply -
HREG  EQU  8
Mac
