Program flash via CAN
AndersJ
I need to field-update a HCS12 application via CAN.
Basically CAN-based "serial bootloader".
Any pointers, or good ideas, anyone?
Anders Johansson
suchita
I have your application note for Flash programming via CAN (AN1828), I have gone through that , In this I want to know that you are saying that in bootloader code it checks for value of $C000, $C001 address register if it is cleare then it will go for flash programming via CAN , But i not getting i will clear this register, So if any oen of you can tell then pls tell me when i will clear this register
bigmac
Specialist III
Hello Anders,
Have a look at AN1828 - although it may be a little old.
Mac
