Breakpoint at main function after Loading Code
sebasira
Senior Contributor I
Hi all!
When code is loaded to the MCU, it runs until main function and then halt there.... Well, I don't know what I've change, it doesn't do it anymore... If I recall correctly it was related to .ini file.
I'm using CW 4.6
Thanks!
CrasyCat
Specialist III
Hello
   Can you try the following:
      - Start debugging the usual way
      - In Hi-WAVE debugger select File > Configuration
      - Switch to the Load tab.
      - Make sure Run after Successful load is checked
      - Check Stop at Function and specify main in the edit box.
      - Select File > Save Configuration
      -Close the debugger and restart it. Application should run to main.
CrasyCat
CrasyCat
Specialist III
Hello
CrasyCat
sebasira
Thank you very much CrasyCat! That solve my problem!
