I have a kwikstik (ver 4) and I'm working with Codewarrior 10.2 and MQX 3.8.
The ADC driver work correctly if make a Debug with a FLASH DEBUG build but don't work correctly in with FLASH RELEASE.
Can someone help me?
Hi alexdev83,
what does it mean your application is not working correctly? Can I test this incorrect behaviour on the ADC example? Let me know.
MartinK
Yes, you can test it with the MQX 3.8 ADC example. The problem is that if i make a debug with a FLASH RELEASE build, the Kwikstik can't open the the ADC0 file, and print on the console "Opening ADC device ...failed"
