Hi ,
I have doubt in linear ram addresing
for ex:
Im using MC9S12XEQ512 microcontroller where the ram memory is 32kb.
where 8kb is non-paged ram and remaining 24kb belongs to paged ram
my placement in linker file goes like this
case 1:
.stack,
.shared data,
.default ram
into RAM ,RAM FD
if i declare a huge array which is shared between both non-paged and paged ram? my microcontroller is getting reset!!!
so my doubt whether a large array can share RAM ( WHICH IS NON PAGED) and RAM_FD( paged) ??.....
2. Whether ram jumping should be linear i.e
RAM FF (NON PAGED) - > RAM FE( NON PAGED) -> RAM FD(PAGED) ->RAM FC(PAGED). ->RAM FB(PAGED)....
Solved! Go to Solution.
Paged RAM requires more difficult addressing. You can't place default RAM and stack in paged memory segments, code won't work. You may put default RAM to paged memory only when using large memory model, but stack still has to be placed in nonbanked memory.
Use search to find how to use paged RAM.
thanks kef... one more doubt....
whether we can pre allocate all the global variables in paged ram...so that i can have enough space for stack and default ram??....
whether we can jump from one ram page to other non-linearly? in sense!!! RAM FE(non paged) - > RAM F8(paged) - > RAM FA(paged) like that!!!!
im sorry if this question sounds stupid!!!
You need to use #pragma DATA_SEG
https://community.freescale.com/thread/109702
I've problems understanding your request.
Hi kef,
sorry for confusing you.
MICROCONTROLLER : MC9S12XEQ512VAGR
1 . if i want to store array say, i.e unsigned int ru_var[200] in to paged ram ( RAM_FA)
i did it in this way,
# pragma DATA_SEG _GPAGE_SEG RAM_ALLOC
static unsigned int ru_var[200]=0 ;
# pragma DATA_SEG DEFAULT
//..................REST OF THE VARIABLES.....
/**********************************************LINKER FILE *************************************************/
PLACEMENT
RAM_ALLOC
INTO RAM_FA ( RAM_FA is allocated by default in the linker file)
whereever extern is used, i did like this
#pragma push
variable.................
#pragma pop
i didn't get any problem while compiling and linking.
While checking the map file ......Array is not allocated in the corresponding RAM page(RAM_FA).
Is there any problem in the way of implementation!!
please help me out kef!
Try with two underscopes, __GPAGE_SEG instead of _GPAGE_SEG
Thanks kef....
