After some time without using MQX, i have received a new project using MQX, so here I am. :smileyhappy:
I've been reading about using the serial port in interrupt and polling mode. So: using ttyb for polling mode, and using ittyb for interrupt mode. But the example project (mqx\examples\io) works correctly using ttyb either ittyb. So, my question is: MQX does something different internally? Or must I do a different code in my application to use ittyb as interrupt mode? For example, using _int_install_isr...???
Thanks for your help
Solved! Go to Solution.
Hi Ardoster,
Please review this previous post and if you have further questions we're happy to help.
https://community.freescale.com/thread/92638
David
Hi Ardoster,
David
