I was informed that setting PLLCLKEN is necessary only when MCG is in FLL enabled mode. If it's in PLL enabled mode, the PLL is already running and the PLLCLKEN has no influence.
best regards
Petr Hradsky
Processor Expert Support Team
Could you please give us more information on:
- What CPU du you use
- What version of software (CodeWarrior) etc..
Or a project demontrating the problem would be also helpful.
best regards
Petr Hradsky
MK20DN512VMD10
cw10.2
WIN7-64
10MHZ Crystal. RTC disabled
best regards
Petr Hradsky
