CodeWarrior Debugger Callstack
ignisuti
I'm using CW10.2 on a Windows 7 64-bit machine
At some point, I had a View in my Debugger that showed me a Callstack. It was called something else and I can't seem to remember what it was called.
Does anyone know. I really miss it...
CrasyCat
Specialist III
Hello
    Inside of Eclipse you usually see the call stack in the Debug View
CrasyCat
ignisuti
Yes, that's correct, but I closed that window at some point and can't remember what it was called.
CrasyCat
Specialist III
Hello
In order to re-open it:
    - Select Window > Show View > Other.
    - Expand the Debug tree
    - Click on Debug.
CrasyCat
ignisuti
Yes, that didn't do it. The Debug Perspective USED to have the Callstack VIEW. Only it wasn't called Callstack, it was called something else that I can't remember.
Resetting my Debug Perspective doesn't help because I've saved the Debug perspective after I closed the Callstack view. Hindsight makes me really wish I hadn't done that, but it should be easy to get the Callstack back if I only knew what it was called.
CrasyCat
Specialist III
Hello
    I have no clue which view you are talking about here.
   I am always getting the Call stack inside the Debug View.
    Did you consider creating a new Workspace and importing your project there?
    This should allow you to return back to the default layout for the debug perspective.
    To create a new workspace, select File > Switch Workspace > Other and browse for a new workspace location.
    This way you should be able at least to retrieve the name of the view you are looking for.
CrasyCat
ignisuti
CrasyCat, you were right all along. I was getting something confused.
Please accept my sincere apologies.
CrasyCat
Specialist III
Hello
No problem. I am glad you get up and running again.
CrasyCat
