Hello all,
Whenever I try to complie TWRk60N512 demo I got the following error
#error SEMAPHORE component is currently disabled in MQX kernel. Please set MQX_USE_SEMAPHORES to 1 in user_config.h and recompile kernel.
I can not find "MQX_USE_SEMAPHORES" in user_config.h !
I already import and rebuild MQX libraries to my workspace. I use MQX 3.8 and CW 10.1
any suggestion?
Solved! Go to Solution.
Just add the line
#define MQX_USE_SEMAPHORES 1
to user_config.h and then rebuild
Just add the line
Yes, I got it. however thank you for your reply.
