I am having some trouble getting up and running with a QoriQ P1021-MDS-PB evaluation board for software development.
I have installed CodeWarrier 8.8 and SP1 to add P1021MDS board support. I have installed NetComm 0.2 driver software supplied with dev board kit. I am also using USB TAP.
When I go through the getting started app 'hello world' the project builds ok, but when I run I get 'CCSProtocolPlugin::Could not connect to the requested core core #0' and 'core #1' errors.
What's gone wrong? Can you help?
Worked out that the JTAG connector was round the wrong way. The plug is not keyed so will go both ways. in 1 (red) must be uppermost on the board.
