I installed the CodeWarrior for MCU V10.1 Special Edition on Windows 7 Enterprise 64-bit Edition. I tried to create new bareboard project of target K60N512. While I tried to build the project, the IDE asked me about the license server or license file. The Special Edition should be pre-licensed but I can not found any license info. Is this correct?
Solved! Go to Solution.
CrasyCat wrote:Hello
Did you look at following thread?
https://community.freescale.com/thread/80580
CrasyCat
I read the thread and add the following line to the cwide_env file in the eclipse folder, the problem disappear.
FLEXLM_BATCH= -add 1
Austin
