Looking for a .mex file for i.MXRT1050 , to use the pin tool. Do not find it in SDK nor in the pin config tool nor in demo app examples . Where can it be found ? thank's in advance
Hello Manu ARDI,
You can see the pin configuration for the i.MXRT on the Pins Tool for i.MX by selecting File>New…>Create new configuration… and then selecting the board from the board options. This will load the .mex file for the EVK configuration. However, this is downloaded from the NXP repository on demand so please make sure you have internet connectivity.
I hope this helps!
