The application note AN13005 states that a FLEXIO_UART7816 driver would exist for the MCU.
I can't find it anywhere.
Is the source available ?
The proposed solution in the AN13005 could be very interesting for my development!
Thank you very much!
解決済! 解決策の投稿を見る。
The Application Note is intended to work as a guide on how to implement an ISO7816-3 driver. So, this driver has to be implemented by yourself, using fsl_flexio driver as a start point.
I’m sorry for the inconvenience this might cause you.
Best regards, Daniel.
Thank you very much for replying quickly.
I now know what to do!
Fred
