I wanna use the 16-bit resolution PWM output as a Digital-to-Analog Converter.
Compared with the conventional 16-bit resolution DAC, is there any difference in terms of the "accuracy" ?
Hi Fun
in conventional DAC "accuracy" is defined by precision reference voltage,
while using pwm one need take into account stability pwm frequency or
filtering components.
