i.MX RT 1064 mcuxpresso sdk api reference manual
2,871 次查看
allen_tseng
I'd like to find "mcuxpresso sdk api reference manual pdf", but didn't find it.
Could you provide i.MX RT 1064's "mcuxpresso sdk api reference manual pdf"?
Thank you
Allen
2,865 次查看
jingpan
Hi Allen,
when you download sdk, you can select downloading documents package. The API RM is in the package.
Jing
2,866 次查看
jingpan
Hi Allen,
Jing
1,569 次查看
GanesanGuru
Hi @jingpan ,
Is there any link to download Bare metal driver for iMX RT1064 ?
Also, I've a doubt - The common MCUXpresso SDK used these MCU specifc Bare metal drivers. Am I right @jingpan ?
If so, I would be enough to master only the MCUXpresso SDK, as it aids in SW developement portability !!!
1,561 次查看
jingpan
Yes, correct.
