SLN-VIZN-IOT Camera options
Netanel
I wanted to know if anyone had a chance to try out a different camera with higher resolution on the SLN-VIZN-IOT board. Something in the range of 2MP.
fangfang
Currently the MT9M114 and GC0308  are the only ones we have officially tested. It's possible that a similar image sensor like the OV7725 would work, but we can't guarantee that at the moment as it's not something we've tested. In general for camera requirements, the solution needs a sensor which supports a DVP interface, RGB or YUV data output, and should support VGA resolution.
Hope it help you. Have a nice day.
Netanel
Thank you for your reply,
Are you planning to update the camera module to a higher resolution ? Are you working on a new Camera module ?
Looking forward for your reply
Netanel
fangfang
Thanks for your feedback. Unfortunately, There is not the more information for it so far. Sorry for it.
Have a nice day.
