Hi everyone,
I'm currently working as Software Engineer on the new iMX-RT 106F kit, SLN-VIZN-IOT.
I downloaded MCUXpresso and the SDK associated with the card to be able to test the power of facial recognition on MCU.
It works well but i'd like to go deeper to test Crank GUI, TensorFlow, ...
Is there currently a solution to add modules in addition to the SDK supplied with the SLN-VIZN-IOT kit ?
Thank you very much.
Cyrille Herlem
Solved! Go to Solution.
Hi Cyrille Herlem,
Is there currently a solution to add modules in addition to the SDK supplied with the SLN-VIZN-IOT kit?
For the moment the SDK is all the available software for this solution.
Victor
Hi Cyrille Herlem,
Victor
Thank you very much Victor !
