Re: booting related imxrt117x
aravindhg
@Pavel_Hernandez
please follow our previous query ....
I am attaching previous thread above iMXRT1170 ,#iMXRT117x
 we are using the following :
1.QSPI based winbond external flash.
2.Yes, but we are facing issues in the newly designed card which is almost similar to our old card.
3.fuses burned as per internal boot mode.
4.boot config and boot mode are internal boot mode.
5. we are using the SWD
6.MCUxpresso link debugger
7. we are using the latest version of MCUxpresso 11.6
8.communication with external flash is not sure, controller is unable to load the code into QSPI flash
I am attaching details again the same.
Aravindh.
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, I reviewed your case, and this is a duplicate could you close this I will continue the support in the other.
Pavel
Pavel_Hernandez
Pavel
