Re: Failed on connect: Ee(42). Could not connect to core. No connection to chip's debug port
nsnmaniram
Hi jeremyzhou,
thank you for sharing the data, the PDF link you have shared uses the IAR IDE,can u please share the steps or any PDF document which uses MCUxpresso IDE options.
Maniram
jeremyzhou
Hi maniram nagothi,
for the opportunity to serve you.
Please refer to the thread:
https://community.nxp.com/docs/DOC-341317
TIC
