RT1050: HAB signature for NOR flash XIP
Search instead for
jayyehtw
I would like to implement the secure boot functionality for my customized RT1051-based device.
The device is running in Xip mode with the IS25LP064A NOR flash.
After reading the rt1050 security reference manual and some material in the forum, the available secure boot methods are:
1. HAB signature only
2. HAB signature + encryption
3. BEE
Option 2 was said not to be feasible for the Xip scenario.
Is option 1 (HAB signature only) feasible for the Xip scenario?
BEE seemed to be overkill for my application, so I would like to know if there's a method to perform application certification only in the Xip mode.
Thanks.
Tags (3)
jeremyzhou
1) Is option 1 (HAB signature only) feasible for the Xip scenario?
-- Yes, and I'd like to suggest you implement the HAB plus BEE for your project.
TIC
jeremyzhou
TIC
jayyehtw
Thanks for your prompt reply.
Please kindly help check if my understanding is correct:
  • For XIP, to realize HAB signature only:
Choose the HAB singed Image Boot form the MCU boot utility and follow the operations.
  • For XIP, to realize BEE only:
Choose the BEE encrypted Image Boot form the MCU boot utility and follow the operations.
  • For XIP, to realize BEE + HAB signature
Choose the BEE encrypted Image Boot form the MCU boot utility and set the "Enable Certificate for HW(BEE/OTFAD) encryption" option to be Yes.
jeremyzhou
Thanks for your reply and your understanding is right.
TIC
