Hi, I'm looking for an exact spec for the xtal on the RT1050. The datasheet gives a bit of a incomplete spec. Would the crystals mentioned in this thread do the job? https://community.nxp.com/thread/308944
Thanks Igor, I have selected the FA-20H 24.0000MF20X-K3 from Epson which I think meets all the requirements.
Hi Martin
since i.MX and Vybrid parts use many same IP modules and particular XTALOSC,
crystals mentioned on that thread also can be used with RT1050. Seems most full
characteristics are given in Table 9. Recommended External Crystal Specifications
i.MX25 Datasheet
https://www.nxp.com/docs/en/data-sheet/IMX25CEC.pdf
