The serial downloader provides a means to download a program image to the chip over the USB OTG 1 and UART1 serial connections .
Thanks & Regards
Vasu
Hello, Vasu
While flashing the board we need to connect two port (USB OTG1 and UART1) ?
No, you don't need to connect both, just the one you are planning to use.
This procedure is common for both internal flash and external qspi flash ?
Yes, this procedure is common for the external and internal flash.
Victor
Hi Victor,
Thank you for your response.
I forgot to mention part number - imxrt 1064.
Non-buildin flash devices like RT102x, RT105x only needed (OTG and UART) interfaces for flashing our distributor telling we can use JTAG for production flash with secure boot this case no need OTG and UART ?
Production flash which software we need to use both internal (or) external flash ?
Thanks & Regards
Vasu
