NXP GUI Guider - display image from SD card support
kashyap_patalia
Hi. I am working on a project where I have to make an GUI application around my MIMXRT1064-EVK and 7" RockTech LCD touch display. In this application I need to show some images(.jpg and .png) and animations (.gif) from SD card. I am able to display images from within the application code. I have made some basic UI also for that using NXP's GUI Guider software. However I am not able to find anywhere how to display the images and animations from SD card.
Any help will be appreciated.
TIA.
Kashyap
gusarambula
Hello Kashyap,
There is some NXP GUI Guider documentation that may serve as reference, like the GUI Guider User Manual (link below).
https://www.nxp.com/docs/en/user-guide/GUI_Guider_User_Manual.pdf
I hope that this information helps!
Gustavi
Vignesh_VInayak
Hi, i have the i.MXRT1170EVK using that i need to display images from the SDcard i read the Guiguider user manual but unfortunately my board is not supported. is there any way to achieve this?
Tags (3)
