Mcu cannot receive packets from ethernet
tianming_ji
Hello,I use imxrt1061 in my project.Sometimes I meet the problem that my board cannot receive any packets  from ethernet.After the board powers up,it can work well.It has LWIP protocol and we can ping from computer to board.After a while,occasionally,we find ping is error.I dump some register values as attached.You can see RMON_R_PACKETS(402D8284): 0000121E and IEEE_R_FRAME_OK(402D82CC): 0000121D.These two register values arenot equal.I think it is abnormal.
Can you explain the meaning of these two register and the reason they arenot equal.Thank you a lot.
tianming_ji
All global data cannot be placed on OCRAM ?Could you give me some more detail explanation about it?
Thanks a lot
danielchen
To make more accurate,   the enet descriptor and enet buffer need to be placed in a NON-CACHEABLE region.    DTCM is  a non cacheable region.
in enet_etherentif_kinetis.c
AT_NONCACHEABLE_SECTION_ALIGN(static enet_rx_bd_struct_t rxBuffDescrip_0[ENET_RXBD_NUM], FSL_ENET_BUFF_ALIGNMENT);
AT_NONCACHEABLE_SECTION_ALIGN(static enet_tx_bd_struct_t txBuffDescrip_0[ENET_TXBD_NUM], FSL_ENET_BUFF_ALIGNMENT);
SDK_ALIGN(static rx_buffer_t rxDataBuff_0[ENET_RXBD_NUM], FSL_ENET_BUFF_ALIGNMENT);
SDK_ALIGN(static tx_buffer_t txDataBuff_0[ENET_TXBD_NUM], FSL_ENET_BUFF_ALIGNMENT);
tianming_ji
I notice your examlpe code:
it doesnot have AT_NONCACHEABLE_SECTION_ALIGN ahead
danielchen
They should be put to NON-CACHEBALE region according to my test.
danielchen
It should be
AT_NONCACHEABLE_SECTION_ALIGN(static rx_buffer_t rxDataBuff_0[ENET_RXBD_NUM], FSL_ENET_BUFF_ALIGNMENT);
AT_NONCACHEABLE_SECTION_ALIGN(static tx_buffer_t txDataBuff_0[ENET_TXBD_NUM], FSL_ENET_BUFF_ALIGNMENT);
tianming_ji
Hi,Daniel:
Thanks for your reply.As we known,the ethernet driver code is from nxp.I want to know whether the official code has been changed like that.
Besides,according to ocram_dma.jpg,DMA visits ocram more effectively than TCAM
danielchen
The official code put the rx/tx buffers into the DTCM.  I will issue a ticket to the software team.
danielchen
RMON_R_PACKETS: Rx packet count statistics register
IEEE_R_FRAME_OK:  Frames received OK statistics register.
It means packets missed during receiving.
Which RAM is the first RAM in your project?  can you dump your memory details?
tianming_ji
Attached is project build link file.
danielchen
Please also check your global data placement, if you place global data  to OCRAM, it will result in packets missing.
