/ MSDK adaptation configuration
#define RAM_DISK_ENABLE
/* Available options are:
/ RAM_DISK_ENABLE
/ USB_DISK_ENABLE
/ SD_DISK_ENABLE
/ MMC_DISK_ENABLE
/ SDSPI_DISK_ENABLE
/ NAND_DISK_ENABLE */
Alberto.
Solved! Go to Solution.
Hi Alberto,
This defines are the different physical drives you can mount depending on your configuration. You should only select one of them as this will be selected when the file system functions are used. With your configuration you should enable SD_DISK_ENABLE.
Felipe
Hi Alberto,
Felipe
