MIMXRT106S project build fails
1,219 次查看
seandutoit
Hi All
I am trying to create a basic project in MCUExpresso IDE for the MIMXRT106S processor using the Project Create Wizard.
After the project is created, I try to build it and it fails with 7 errors.
Are there any special settings for this processor?
9 回复数
1,144 次查看
jingpan
Hi @seandutoit ,
No, there isn't. Same to RT1060.
Jing
1,140 次查看
seandutoit
Why will the project not build? What information do you need me to send you?
1,137 次查看
jingpan
Hi @seandutoit ,
You can start from a hello_world example in RT1060 SDK.
Jing
1,133 次查看
seandutoit
This project builds fine but I am having problems in programming the device on the custom board
1,108 次查看
jingpan
Hi @seandutoit ,
What is your customer board? What is the flash on the board?
Jing
1,096 次查看
seandutoit
The custom board has QSPI flash
1,076 次查看
jingpan
Hi @seandutoit ,
You can use Security Provisioning tool to connect RT106s via serial mode. Let it recognize the flash, make a full erase.
Then you need a flash download algorithm for IDE downloading and FCB for flexspi config. Different flash may has different algorithm and FCB.
Jing
1,048 次查看
seandutoit
As this chip is a brand new chip from the factory, Is there anything special I should do before trying to program it. I am even trying to run a application from RAM but that also is not working.
Is there a minimum number of pins that should be connected before programming the device. Maybe I am missing a pin connection. Where should the JTAG_nRST from debugger be connected? I now have it on Pin G10.
I have Boot Mode0 and Boot Mode1 pins connected. Are any of the other pins important on a new device?
980 次查看
jingpan
Hi @seandutoit ,
I doubt your board isn't power up correctly. Please measure VDD_SOC_IN pin. Is it around 1.1V?
The attachment is RT1060 EVK schematic.
Jing
