Any download URL fro this? Would you recommand us to use this Rev A1 kits or we should use Rev A2 instead?
kc
Solved! Go to Solution.
Hi @kc549 ,
Yes, of course, blhost works, my board is also the A1 version.
If you have issues, I suggest you use the MCUBootUility tool, which is the GUI for the blhost:
https://github.com/JayHeng/NXP-MCUBootUtility/archive/refs/tags/v3.4.0.zip
the related user manual is:
Very easy to use tool.
Wish it helps you!
Kerry
Thanks Kerry for fast response. Do you know for whether blhost utility works with this Rev A board?
Kevin
Hi @kc549 ,
Wish it helps you!
Kerry
