KSZ8081RNB alternatives for I.MXRT1060
patriciocohen
I'm having a terrible time trying to get the KSZ8081RNB PHY for my PCB. They are not available anywhere.
Is there a compatible alternative?
Please help.
Patricio
Tags (2)
jeremyzhou
According to your statement, it seems like your PCB board is ready and you want to find an alternative Physical Layer Transceiver whose pins are compatible with the KSZ8081RNB.
Is my understanding right? If yes, I'd like to suggest you'd better to contact the Micorchip, as it's nobody know their product than them.
TIC
patriciocohen
Hi Jeremy,
We are open to change the layout and manufacture a new board if necessary.
Can you please indicate compatible alternative PHYs for the Imxrt1060 family?
jeremyzhou
Thanks for your reply.
1) Can you please indicate compatible alternative PHYs for the Imxrt1060 family?
-- In actuality, the RT1060 can work with most mainstream Physical Layer Transceiver, like the KZ80xx, DP838xx, etc.
TIC
patriciocohen
Hi Jeremy,
For using any of those chips do I need and special driver? Or can I continue to use the same software that I have for the original design?
Thank you
Patricio
jeremyzhou
In my opinion, it should be Okay to use the same driver to driver the KZ80xx chips, however, the driver software need to be adapted if use other Physical Layer Transceiver chips.
TIC
