Issue with creating bootable image for RT-1050
781 次查看
bzhang3
Hello All,
I'm using Keil IDE to build code to execute from the hyperflash on the RT1050 EVKB. When I load the code onto flash and run in the Keil debugger, everything works fine. And when I close the debugger and power cycle the board, code still executes successfully from flash.
Now I'm trying to build a bootable image and use the MFGTool to load code onto the H-flash. I'm running into issues. Here's steps I followed:
1. Creating a s-record file with the .axf generated by Keil (test.axf and test.srec attached):
      "fromelf --m32combined --output=test.srec test.axf"
2. Creating binary file with elftosb:
      "elftosb.exe -f imx -V -c imx-flexspinor-normal-unsigned.bd -o test.bin test.srec"
The output test.bin only has 0 bytes. However if I use the led demo in the example images of the FlashLoader, I can generate a .bin file successfully.
Can anybody help me figure out what the problem is? Many thanks in advance.
Bin
0 回复数
