IMXRT1176 debug application in SDRAM through JLINK
nxbg
Hi Team,
In order to do debug inside SDRAM as my project is quite big now. I download evkmimxrt1170_connect_cm4_cm7side.jlinkscript from previous topic attachments, but actually the newest 2.10.1 SDK does not have this file actually(I extract the SDK file and search this file but got nothing).
Another problem about this script is that, after download application to SDRAM, everything works fine, but if we stop application then click restart(Used very frequencely when we are debugging), then nothing happened, so we need to download again.
Could you help to check a little bit about this small issue?
Thanks & Best Regards,
kerryzhou
Hi @nxbg
I checked the SDK2.10.1, it contains the jlinkscrypt, please check the helloworld project folder
Kerry
kerryzhou
Hi @nxbg ,
  Thanks for your interest in the NXP MIMXRT Product, I would like to provide service for you.
  So, you use the .jlinkscript from the SDK2.10.0, do you test the SDK2.10.0 directly, whether you meet the same issues?
  Please also tell me your JLINK dirver version?
Kerry
