I use the IMXRT1010 EVK and the MCUXpresso; I configured the LPI2C in transfer mode and the SAI in interrupt mode (word); both units work right but not at the same time.
The LPI2C works correctly only when I don't enable the SAI interrupt, if I enable the SAI interrupt the
"LPI2C_MasterWaitForTxReadyF(LPI2Cbase)" seems to freeze the code....
Anyone may help me ?
Thank you, Luigi
已解决! 转到解答。
Could you please tell me the SDK version you are using?
Could you confirm SAI works correctly if it runs independently?
By debug mode you mean you have a debug session running, am I right? Is this problem still occurs if you don't run it with the debug session?
Daniel.
Daniel.
