Https server with json request and response
vasudhevan
Contributor V
     Board - imxrt 1064
     How to implement https server with json request and response format ?
     Any documentation available nxp https server apis ?
Thanks & Regards
      Vasu
kerryzhou
Hi Vasudhevan G,
   About the https server code for MIMXRT1064, you can download the SDK for RT1064, please select the middleware LWIP.
SDK_2.7.0_EVK-MIMXRT1064\boards\evkmimxrt1064\lwip_examples\lwip_httpsrv
About the cJSON code, you can download it from this link:
GitHub - DaveGamble/cJSON: Ultralightweight JSON parser in ANSI C
You can try to add it to the lwip code.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
vasudhevan
Contributor V
Hi Kerry,
    Thank you for your response.
    Any documentation available regarding http server apis ?
    How web page sending to when .html request comes ?
Thanks & Regards
         Vasu
kerryzhou
Hi Vasudhevan G.
  The http api used is from the LWIP,  the LWIP can be fond from this link
lwIP - A Lightweight TCP/IP stack - Summary [Savannah]
You can find the API description from the above link.
Wish it helps you!
Kerry
