How to burn imageto sd
Search instead for
jingyangxie
Contributor V
I have a rt1170 board, how cound I use JTAG to burn image to SD
Tags (2)
CarlosGarabito
Hi @jingyangxie you can try to use a MCUBoot Utility (https://github.com/JayHeng/NXP-MCUBootUtility) it can help you
CarlosGarabito
Could you explain what do you want to do with more details?
jingyangxie
Contributor V
I want use SD card as boot device, so I need to burn app to sd,Is there any way to use Jtag to burn app to sd directly like other flash?
CarlosGarabito
