How to add program protection function to RT1060 and RT1064
915件の閲覧回数
lw3
Prohibit reading programs through SWD or serial or USB methods
Can encryption function be enabled
Can the flash run normally when switched to another MCU
How to Prevent Copying Flash and Replacing with Other RT1060 MCUs from Running Properly
8 返答(返信)
890件の閲覧回数
lw3
After adding read protection to the jlink swd interface
Can we use the swd port of jlink to download new programs again in the future
883件の閲覧回数
jingpan
Hi @lw3 ,
Yes, please refer to AN12419.
856件の閲覧回数
lw3
Can you give me the download connection for AN12419
847件の閲覧回数
jingpan
796件の閲覧回数
lw3
I'll study how to use it
796件の閲覧回数
lw3
Thank you
900件の閲覧回数
jingpan
Hi @lw3 ,
To prevent unauthorized read from SWD/JTAG, you should enable SJTAG.
To prevent copy code, you should use BEE and encrypt the code in flash.
Jing
