Does P&E micro USB-ML-UNIVERSAL debug probe support imxrt117x controller
Jeevan
Hi team,
We are using imxrt117xx controller with MCUXPRESSO IDE. Does P&E micro USB-ML-UNIVERSAL debug probe is supported for above controller?
If it is supported to which should we connect on the debugger device (ex: Port C - BDM port)
How many pins and which pins do we need to connect from debugger to the controller?
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, maybe this document will explain more about the SWD port but let me know if have more doubts.
Pavel
