I want bridge my own wearable display to MIMXRT595-EVK.
There was no any spec. information about DSI connector(J44) of EVK.
Could you share connector vendor or part name? or pitch? contact on both side or single side?
Thanks.
Solved! Go to Solution.
Hi @IronMouse ,
Check the following information for J44:
description:CON 1X40 FPC SMT RA 0.5MM 89H AU --
package: con_fpc_40f_0p5_smt_ra
Manufacturer: WURTH ELEKTRONIK EISOS GMBH & CO. KG (ELECTRONIC & ELECTROMEHANICAL COMP)
Wish it help syou!
Hi @IronMouse ,
Wish it help syou!
Hi @IronMouse ,
I already help you to check with our internal side, just to check the MIMXRT585-EVK BOM file.
From the EVK, J44 is single side, about detail information, still need to wait the internal response, please keep patient, thanks.
kerry
