I am using the MCUxpresso SDK version 2.8.2 and MCUxpresso IDE version 11.2.0. MCUxpresso Config tool version 8.0.
I have added the USB device driver/middleware packages. But still the Config tool claims that "Component USB device is missing in the project". Also the "USB common not found in the toolchain/IDE project.".
But as far as I can investigate, they are added to the project (and it compiles!!). The context menu "Add SDK component" works, but does no difference.
I believe this is "just a bug", and I safely can ignore it.
Forgot to mention that the USB Stack is included in the SDK build.
Could you please let me know the MCU you are using?
The MCU is MIMXRT1064DVL6A, but the problem is probably for the whole series.
could you please attach your error message, I can not reproduce this issue. Thanks
