Change Record time
Change Record time
nahan_trogn
Hi, I can run the evkmimxrt1060_tensorflow_lite_kws example. But now, I want to change the time of recording my voice. For instance, I want the micro record my voice in 2s, then preprocessing it and inference the output. How can I achive this? Thanks.
jeremyzhou
1. In my case, if I want to process 2s audio, I will set the NUM_FRAMES = 100-1?
-- Yes.
2. In tensorflow_lite_kws example, does the micro automatically record? How I handle to start/stop record by manual? I want to use timer 2s to record the voice then process it.
-- Yes, the micro records automatically, of course, you can handle it manually, however, you'd better spend time to know the software architecture prior to change the demo code, as the demo code is more complicated than other demos in the SDK library.
TIC
jeremyzhou
1) How can I achieve this?
-- Firstly, you need to retrain the model to suit for 2-second voice data, please refer to the article to make it, next, modify the macro definition:NUM_FRAMES which residers in kws_mfcc.hpp in tensorflow_lite_kws demo, it's easy to do it.
TIC
nahan_trogn
Thanks for the answer,
So 1 NUM_FRAMES = FRAME_SHIFT_MS = 20ms in tensorflow_lite_kws example?
jeremyzhou
Thanks for your reply.
1) So 1 NUM_FRAMES = FRAME_SHIFT_MS = 20ms in tensorflow_lite_kws example?
-- No, NUM_FRAMES stands for the amount of the frequency analysis sample, and FRAME_SHIFT_MS stands for how far apart each frequency analysis sample is from the previous.
TIC
nahan_trogn
Thanks for your answer,
1. In my case, if I want to process 2s audio, I will set the NUM_FRAMES  = 100-1 ?
Wish you a nice day.
jeremyzhou
-- Yes.
TIC
nahan_trogn
The micro records automatically and save the audio to a buffer. Where can I find that buffer and how much data can this buffer store?
jeremyzhou
audioBuff array is used to save the audio data.
Hope this is clear.
TIC
