1060 evk12 cannot debug
jingyangxie
Contributor V
I have a board(imxrt1060-evk12) ,when i use the sdk2.12.1 for 1060-evk, it cannot debug with flexspi_nor link file:
lucas_cao
Hi @Alice_Yang  and @jingyangxie
RT1060 EVK12 used HyperFlash as the boot device.
So if you are using RT1060's SDK, it makes sense that it cannot work well.
You can try RT1050 SDK becasue it uses HyperFlash as the boot device.
BTW, where did you get the RT1060 EVK12 board? By university program?
Hello @jingyangxie
It seems there is an issue with the boot jumper:
Have a look at :
https://www.nxp.com/document/guide/get-started-with-the-mimxrt1060-evk:GS-MIMXRT1060-EVK
Alice
jingyangxie
Contributor V
I have changed the SW7 to 0010, but it still doesn't work.the log as follows
Hello @jingyangxie
Which demo do you run? How about iled_blinky under SDK?
Alice
jingyangxie
Contributor V
it can not work too if I use the flexspi_nor.icf link file
