How to stream MJPEG in OV5640 + i.MX RT1170 dev kit
balasubramaniyam
Our requirement is to stream MJPEG format in the i.MX RT1170 dev kit through ethernet (Network streaming). From the forum or NXP website, I can get RGB or YUV-based streaming driver for OV5640 + i.MX RT1170 dev kit.
Is there any driver available to stream MJPEG?
Many thanks in advance, regards,
Bala
jingpan
Hi @balasubramaniyam ,
 In SDK, libjpeg source code is provided, customer only need to do it according to AN12110.pdf. You can see the USB virtual camera example use mjpeg format.
There isn't examples of sending MJPEG by ethernet. There is UDP/TCP demos in SDK. You can refer to them.
Jing
