zero cross detection by BEMF IMXRT1024
113 次查看
M410
hi , recently im working on project to build the ESC with imxrt1024 with flexPWM and internal comparator as BEMF detector ,  what ever i did got no result to detect good BEMF detection and it got to much noise , first of all please share any idea to get better result and then i found that pwm chopping make the cmp anct noisy i wonder is there any way to sync pwm signal with cmp to get sample when it is in high PWM signal ?
1 回复
50 次查看
Sam_Gao
Hi @M410
Thanks for your questions, would you please clairfy more about the queston"build ESC with imxrt1024 with flexPWM and internal comparator as BEMF detector ,  what ever i did got no result to detect good BEMF detection and it got to much noise" for better support you? such as test environment, reproduce steps, what's the background of this project with some evidence( figures, data,, etc.) related to the question?
[test environment]:
1. hardware: i.mxrt1024-evk board or others?
2. SDK/Example: ?
3....
[how to reproduce]:
Thanks for you undertand.
B.R, Sam
